- Allow the text line (tail) to have more than one line of test! Many times I’d like to add a 2nd or third line to the process. (And fix it so I don’t have to add a space at the beginning or the end of the text line, so it doesn’t run into the < of the tail!)
- Fix it so the line is adjustable. If I have just the fillet mark, I don’t need a line sooo long. And, if I have 4-13/16" welds every 5-1/4", the numbers all jumble / run into each other.. The line won’t adjust itself to fit! Make it so you can drag the length of the line.
- Mainly for plug welds, but if I don’t have a number of welds (number under the symbol), and I ask for a surface (flat, concave, etc..) the surface feature indication is way below the weld symbol, so far that it can be considered an extraneous mark on the drawing, not a part of the symbol!
- Make the leader reference notes independent. As it is now, you have to choose left or right sides (and they seem backwards), and if you flip the weld symbol, you have to re-enter the text!
