Welding and machining
Welding features are not affected by following machining: if there is an assembly feature i.e. an hole or a milling, the welding looks not modified. This could cause big problems of misunderstanding. It exists a workaround, but it is not correct and it causes a loss of time and a bigger model with several family tables.
Other 3D CAD allow this modification (Inventor).
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
