Hello,I'm a Chinese engineer.
Since Creo3.0,Model's filename can be Chinese.But when I export an assembly as STEP,it's filename and all the components' filename become to numbers,like 100_1_1.prt. So can Creo remain the Chinese filename? Thank you very much!
从Creo3.0开始,模型的文件名支持中文。但是当我把一个装配导出为STEP时,他的文件名和所有子件的文件名都变成数字,比如100_1_1.prt。所以在导出为STEP时,Creo能否保留中文的文件名?谢谢!
