When importing ECAD EMP/EMP file using Investigate Geometry & Placement options, components in pattern are replaced with individual components instead of retaining the pattern. All relationships with children are then broken. This is VERY serious, especially panel cutouts are that reference the shape of components in patterns that ProE then simply removes! These cutouts will then fail and everything will be broken.
Product Management considers this an improvement!
Case: 12319038
SPR: 2252626
