Today when you use the "Note from file" the start directory is the wrokspace/work directory, instead of the directory set in the pro_note_dir.
To get the pro_note_dir you have to click on the "Note text Directory" folder under common folder to get to it.
99% of the time you whant a note from the directoy not a note saved only in the workspace.
Therfor the "Note from file" should start up in the pro_note_dir.
