Windchill Check In Failure in Creo - Automatic Popup to Make Failures More Obvious
When a Windchill Check In fails within Creo, users have to notice that their check in failed in text in the bottom left of Creo (not obvious), notice/click on a cryptic icon at the bottom of Creo (not obvious), and then have to dig through several menus to find out why (not obvious). This is frustrating - especially to new users. Please create an automatic popup window for critical Creo/Windchill event failures that allow users to easily see (within one click) why the check in failed. This could be applied to other important event failures: check in, check out, revise, etc.
Current State:
Future State:
4 Comments
BenLoosli
Make it an option...experienced users know how to find their errors.
Config.pro setting: error_mode_display verbose|minimal
lhoogeveen
If it is an option including Windchill in the name would be helpful. windchill_error_display_msg yes|no.
I would vote for setting this to yes by default.
lhoogeveen
@lwestbrook This idea could help make using Windchill Gatekeeper with Creo ModelCheck easier.
lwestbrook
@lhoogeveen Thank you!
