Would like to Copy a View that contains Configurations
We would like to be able to 'Copy' a view within an Annotation drg.
The reason is to show different iterations of an assy, using a copy of a detailed view.
For example, we would like to show an assy with an ASME flange, ANSI, JIS etc...
The parts in the assy can be established using Configurations (drawlist) - or even to a degree, Manage Views.  Unfortunately at the moment, each iteration requires all the detail to be 're-added' (duplicated) in each view.
This may also require some suggestions relating to the way that dimensions are recognised on views with configurations....!
2 Comments
bcritchley
7-Bedrock
Hey Max, no problem with 'Down' votes, but I am curious to the reason,
Barry
olivierlp
Community Manager
Status changed to: Archived
