there is NO Toolkit API yet available that could write the ProMechModel object/handle that was generated by API ProMechmodelGet() to a file
If we can open this file in Creo then it will help to check how ProMechModel is created (for example which faces, edges are merged from Native model).
This will help a lot before setting and meshing analysis.
