add function to retrieve the Layer Rule data, possible api could be:
struct pro_layer_rule * ProLayerRule;
ProError ProLayerRuleGet( ProLayer *layer, ProLayerRule *p_rule); //get ProLayerRule object from ProLayer
ProError ProLayerRuleSet( ProLayerRule rule, ProLayer *p_layer); // set ProLayer with ProLayerRule
ProError ProLayerRuleDelete( ProLayer *p_layer); //remove rule from layer
ProError ProLayerRuleIsEnabled( ProLayer *layer, ProBoolean *p_enabled); // get ProLayer rule enabled/disabled status
ProError ProLayerRuleEnabledStatusSet( ProLayer * layer, ProBoolean enabled); //set status
ProError ProLayerRuleIsAssociative( ProLayerRule rule, ProBoolean * p_is_associative); // get associative status
ProError ProLayerRuleAssociativeStatusSet( ProLayer *layer, ProBoolean associative); //set associative status
ProError ProLayerRuleIsFromExternalModel( ProLayerRule rule, ProBoolean * p_from_external); // get 'independent' status
ProError ProLayerRuleProRuleGet( ProLayerRule layer_rule, ProRule *p_rule); //get ProRule data from ProLayerRule object
ProError ProLayerRuleProRuleSet( ProRule rule, ProLayerRule * p_layer_rule); //set ProRule data for ProLayerRule object
Creo 3.0 ProLayerRuleCopy(...) takes care of the situation when LayerRule has to be set from external model but the API is somewhat incomplete...
