add in quick access toolbar, Creo2.0
When adding to quick access toolbar, it is necessary to add commands in each mode(ex. part mode, assembly mode...).
We want to add commands in all mode. or selectable.
3 Comments
lroose
1-Newbie
PTCModerator
Emeritus
mfischer
Status changed to: Delivered
In recent releases of Creo, commands added to the the Quick Access Toolbar are propagated to all modules in Creo.  In fact, propagation is on by default.  You can choose to remove propagation if desired though the Customize: Quick Access Toolbar section in the Creo Parametric Options dialog.  Right mouse on the top-level item and un-check propagation.
Those commands added to the the toolbar will be accessible if they are relevant in the given module you are working in.
Mark Fischer
Sr. Director, CAD Product Management
