allow arcs to be converted to circle
In sketch mode, it should be possible to convert arcs to circles.
6 Comments
MikkoHinkkanen
Join sketcher elements command in general:
  • Arcs to Arcs
  • Arcs to Circles
  • Lines to Lines
  • Splines to Splines
  • Conics to Conics
One can trim and divide - but not join elements in sketcher.
S_Edgenear
There's a workaround, that is to create a united new entity, and replace the old with the new.
Maybe will not work in all the situations, but I find that in most cases, it solves the problem.
It keeps the ID in downstream operations. The only downside is that we have to again re-consrtaint the new sketched entity.
T_F
That's a workaround, that gaves a lot of work...
S_Edgenear
I agree, if it can be implemented as requested, more productivity we can gain. I just mentioned it, cause there could be someone who didn't know what to do in that case.
T_F
Yes, you did well
SXS_CADADMIN
3-Visitor
This would be a great time saver if implemented.
