allow to change tolerance tables in family tables
It could be useful to be able to change a tolerance table within the family table along with the dimension
6 Comments
jwaldorf
1-Newbie
I'm currently having issues with this.  I have a family of parts that I need to produce.  Most of the dimensions have a specific tight +/- tolerance (example: +000 / -.001) as required by the customer to meet existing parts.  If I dimension a feature on a single part, I control tolerance information.  Why does PTC remove this capability in Family Tables.  This is basic stuff here.  Does anyone have info I'm missing? any help would be appreciated.
Dale_Rosema
23-Emerald II
BASTIAN SKOTZEK
You may want to vote on your own idea....
TomU
This appears to be current functionality, at least in Creo 3 M050.
Dale_Rosema
23-Emerald II
Ryan Kelley
If this is current functionality, then maybe it should be changed to that?
ryankelley
1-Newbie
As Dale suggested, I've marked this Product Idea as "Current Functionality".
PTCModerator
Emeritus
Status changed to: Archived
