associated drawing should also get copied when replacing a part in assy. with copy method
This is already existing functionality.
Please use config.pro option:
rename_drawings_with_object both
and possibly option:
remember_replaced_components no
Dear Mikko,
your suggestion is not belong to my query
rename_drawings_with_object both is used to copy a drawing along with part, when we use save a copy command
remember_replaced_components no is useful to brake dependence with replaced part, which help to create ghost object in Windchill
my query belong to following image,
when we replace part in assy. using "by copy" method, associated drawing should also get copied
