In response to document CS67713, there should be a setting developed to allow "negative" lower tolerance values as a default. Currently, if you have a "-.000" lower tolerance and change one digit, the sign flips to positive. This functionality is fine for those using metric tolerances but not for everyone. A config setting to set lower tolerance to negative as default should be developed.
