automatic or manually delte empty layers "hidden items"
Actually ther are many empty layer into the view off all komponent layers of bigger assemblies.
The layer idea only effecivly used for work when there ar only layers are stored in the models that have any object reference realy.
Only "standard layer" "hidden items" can not be deleted.
4 Comments
mganzer
1-Newbie
To get around this we created a mapkey that would remove all empty layers from the layer display. We did not want to permanently delete any currently empty layers since they were rule based.
Dale_Rosema
22-Sapphire I
Sven Glause‌,
You may want to vote on your own idea....
sven
6-Contributor
Hi Mark,
your mapkey find all non empty layer and set on isolate? Is o.k. as an workaround up to ptc realize this idea, thanks...
@dale thanks
olivierlp
Community Manager
Status changed to: Archived
