Reactions force visualisation is not possible in Creo for geometry not attached with beam finite element.
In "Creo Simulate Results":
Window "Result Window Definition"
"Display type" = "Model"
"Quantity" = "Reactions at point constraits"
Reaction force visualisation is not possible when "resitriction" is not attached with beam type finite element.
Reactions forces has to be obtain on all finite element type : 1d ( rigid, spring ), 2d (shell element), 3d
There is a risk that the user do not verify his FE model reactions force because these results are not available.
He has to model beam finite element linked to obtain reactions forces.
This is particulary true when reactions force are spread in the finit element model.
