change "Select Combined State" popup for new view
Starting I think in WF4 the combined state was introduced. If you aren't using combined states though when you insert a new assembly drawing view the software prompts you to select a combined state anyways.
It would be nice to either change this to be in the view properties or somewhere else so it doesn't always automatically pop up when inserting a new view.
Alternatively a config.pro option to revert back to the pre-WF4 functionailty without the pop-up would be nice.
3 Comments
Guest
Starting in Creo Elements Pro 5 M230 and Creo 2.0 M110 there is a config.pro option drw_prompt_for_combined_state. If you set it to no. That should keep the "Select Combined State" popup from occuring.
Amethyst
Good information. Thanks Brian.
Community Manager
