1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Creo Parametric are you currently running?
Creo 8.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
It would be good to have the possibility to configure Creo to set by default the extrusion
of a part as symetric
(or other) instead of blind.
Have a config.pro option to set this option.
4. What is the use case for your organization?
Daily work
5. What business value would your suggestion represent for your organization?
Development efficiency.
