creating combined state, independent from view
it is possible to create a combined state. When creating a combined state, you can set the view type and which kind of layer state. when editing the 2D drawing of this component I can't select a combined state, because it is depending of the view. it is preferred to make this independable. So I can choose a combined state independed from the view. see picutre below.
preferred is to select a combined state independed from view
2 Comments
fmarinier
7-Bedrock
I really agree with you, why should I specify the orientation when already done in the Combined State definition ?
1/ First in the View Manager, this is my Combined View definition. You can see that the orientation is specified.
2/ After that in the drawing, in the view properties, I can't select the Combined State.
Have to reorient the model before ?!?
Lost of time and not really flexible
PTCModerator
Emeritus
Status changed to: Archived
