Currently its not possible to use the option "Use parent view style" for projection views. Users want to get this option also for projection views
and not only for detail views. Very often it happen that users create parent views which are different to the default settings of display styles. So
when user now create a projection view so it would be great when he can choose the option "Use parent view style" also for this type of view and
View properties >> View Display >> View display option "Use parent view style" ... should be useable for all views!
