We are a value-added resellers of PTC Creo software and my role is an application engineer.
Currently, I am using Creo 8.0
I am looking for warpage analysis in CMA but currently, it is not part of the Creo parametric software.
See
Warpage in plastic injection molding is when the intended shape of the molded part is distorted during the cooling process. Mold warping can cause the part to fold, bend, twist or bow.
So the industries where the accuracy of the part is important but due to unavailability of this functionality make a buyer search for another solution
If this is available or comes as a new feature then it would add value to the organization in terms of part-level aesthetic and assembly accuracy and save a lot of money.
