Similar to how most other CREO files have iteration #'s, add the iteration number ( .1, .2, .3 ...) to the end of the file name of creo_parametric_customization.ui
creo_parametric_customization.ui.1
creo_parametric_customization.ui.2
creo_parametric_customization.ui.3
This allows recovery of a setting that may have been changed unintentionally. The previous customization file "config.win.x" used the iteration number.
