The following is an enhancement request from HOSHIZAKI ELECTRIC Co.,LTD..
Although it is a semicircle model, a detum axis center line is despayed on the whole
when setting detail option "radial_pattern_axis_circle = yes".
The center line is displayed till an unnecessary place.
When holes are created by directions up to 180 degrees with an axial pattern,
They would like to display a detum axis center line to a semicircle without the unnecessary line.
