edit definition of the sketch in sweep feature
Currently even in Creo 4.0 I see missing direct edit definition under RMB context menu for Sweep feature - it is the time in my eyes to fix it
it should look like for example in Extrude feature:
i use customise and add missing button, but this need improvement because the button is not working at all and user can only edit dimension, not definition of the sketch...
Please hear my voice here
4 Comments
MikeLockwood
22-Sapphire I
There must be some constraint on this but I can't see what it is. I'm constantly re-defining sketches used for sweeps, and it takes just that one more click to access it.  Just slightly annoying.
rsobecki
Mike, I use mapkey to edit definition of the sweep feature and second mapkey to edit sketch inside - of course only when need to add or remove some curves...
My objective here is to have direct acces to sketch edit definition as same as we used to have in extrude or revolve
psobejko
It would also be would be easier in many cases if one could specify the sweep section to be an external sketch (in the same way one can extrude such a stand-alone sketch).
olivierlp
Community Manager
Status changed to: Archived
