embossed intersection on cylinder should be movable axial
when you want to stretch a edge of a cylinder, which was made as embossed intersection, you can move in every direction, you want to, except axial. This should be possible - it's the easiest direction, you can define!
3 Comments
FelipeRosendo
1-Newbie
You might consider reporting this as a  product defect through support
ptc-2537043
Hi Felipe,
before i placed this idea, a support-case at PTC was opened by me. I got following answer from PTC: This functionality is not part of product. Missing things cannot be wrong!
Then they told me, to open this as idea....
My personal opinion - it's a bug in the command.
Sven
PTCModerator
Emeritus
Status changed to: Archived
