Please give us a simple way to fix and change the reference of a baseline of ordinate dimensions that fail.
I am running into this problem from time to time, and the process is really really time consuming. If there are easy dimensions, it just takes time, but if there are complicated conditions like tangency, this can be even more frustrating.
So of course I went to see what was out there regarding this topic.
As of TAN112745 we know that:
Resolution
This issue will be resolved in a future release of Pro/ENGINEER.
But it popped up again in Creo 3 with CS195198:
Release | Status | Datecode |
Creo 3.0 | No Plans to Fix | - |
By seing CS69648 and CS206139 we learn that we should recreate the dimension completely.
As of CS106382 we are informed that this is: Not part of the Pro/Engineer functionality
In CS28790 we see a hint of a bit of light at the end of the tunnel:
Resolution
But in CS202291 we learn that it is not at all possible to move the reference of the base line even if it has not failed.
So I am not the only one who stumbles across that topic.
So this Idea is about resolving the issue as promised in TAN112745, many thanks for listening 🙂 ?
