have the possibility to show dimension of the second repeat feature in MBD
is it possible to add the possibility for show the dimension not only from the first one feature which is repeated in a MBD environment ?
2 Comments
Community Manager
MFR Bedrock
Bedrock
I would like to get more info regarding the use case here. why this functionality is needed? how often this is needed and what is the reason behind having this vs noting x3 for one of the instances instead. please note that these are driving dimensions and not driven ones, which means that only one source of truth for the dimensions must be kept (only one driver)
