hide/show datums of a part with right click
Just an improvement that would make things easier to use in large assemblies. Currently, If you want to show or hide just a few parts planes, you have to go find that part number in the layer tree, or you can select the part through the layer tree selection, which isn't too bad. But it could go one step further where there was a show/hide pull out menu on the right click where you could select a part, right click and then show or hide axis, points, or planes. There already is a hide for the whole part, you would just add the triangle fly out to get to other options.
2 Comments
auijttewaal
7-Bedrock
PTCModerator
Emeritus
Status changed to: Archived
