Adding the ecad-mcad attribute "npth/pth" to the hole feature dashbord, would improve the consistensy in the WoW. This shall also include the visibility in the model if "pth" is selected, a suggestion would be to generate a ecad teature on both sides of the "PCB". The size/type of that ecad feature to be controled by a config file, simular to the "thread" settings.
