I just read this document
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS151960&lang=en
it recommends to create a feature parameter ECAD_HOLE_TYPE type string with the value MTG for the holes that shall be exportet as MNT instead of PIN.
Wouldn't it be great if a table for standard holes could be used for that?
e.g. using a ECAD.hol to make this features would automaically add the feature parameter ECAD_HOLE_TYPE = MNT?
