horizontal radius en diameter dimensions in Annotation
it would be nice if you could set the default orientation for radius and diameter dimensions to horizontal, while for other dimensions the settings remain parallel.
4 Comments
GaryLinscheid
What is your standard set to?
wdesmet
3-Visitor
my standard is set to ISO.
Changing it to ANSI or DIN did not change the behaviour
FriedhelmK
If you want you can have a look at this idea
http://communities.ptc.com/ideas/1690
Keeping linear dimensions Parallel but radius and chamfer horizontal
there i wrote a solution for this.
PTCModerator
Emeritus
Status changed to: Archived
