improve the project outline command for multiple parts
this would be such an improvement if you could select multiple parts to project them onto a workplane. now you have to restart the command again after each time you have executed the command.
i would already be very happy with just a next button
2 Comments
FriedhelmK
Work around to make it a little faster.
Put the command in the Command Mini Toolbar "Single part"
Then you can pre-select a part, press the command and confirm with the mouse wheel.
Next part ..... and so on .....
This goes a bit faster.
Friedhelm
PTCModerator
Emeritus
Status changed to: Archived
