When exporting Creo drawings to dxf we noticed that anything that was set to phantom line font (components set to phantom opaque), some lines are showing solid instead of phantom. Upon further investigation, we found that the linefont scale in the dxf is too large.
We need a config option to control the linefont scale when exporting from a Creo drawing to dxf.
This is a problem for all our Kit drawings where the reference assembly is in phatom line and the bag of parts in the kit are the only thing that is solid line. Since the dxf files are not showing correctly, then it is very confusing to tell what parts are really in the kit and what parts are not supposed to be in the kit.
