To have better integration beetween Creo and Creo Elements Direct is a good idea to add the possibility to load Creo Parametric drawing files in Drafting/Annotation
Consider a customer that use both software in different division, this can help the users to reuse data witout translation.
Best Regards
Franco Mazzucchelli
