machining label should be different then regular labels
it should be possilble to deactivate the labels generated by machining features individually. machining labels can often be anoying, certainly when used in a pattern. therefor you have to put labels OFF, but then all labels are deactivated like 3D annotations.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
