machining validate to chatty
Every time a machining feature is validated a message is posted in the output window.
1. This is of very little use for the user. If there is a message when a problem occurs then it is ok, but not every time when something is done correctly.
2. Quick menus are interrupted
3. The user has to do additional clicks that slows down his work.
A lot of users are very unhappy about this.
When the program thinks that is so important to announce that his program has worked fine, then he could also use the sd-display-alert function.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
