The measurement tool should be able to also measure max distance of curved surfaces. If I need to know the distance between a flat surface/plane and cylinder edge, currently you can you pick "through axis" and "not through axis" which is essentially the minumum distance. If you need the max distance you have to find some other way to pick the edge.
