model check overall_size parameter should only report solid geometry
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
out includes curves and surfaces
2. What version of Creo Parametric are you currently running?
7.0.3.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
overall size includes surfaces and curves
4. What is the use case for your organization?
We report overall size of the part in a note in a combination view
5. What business value would your suggestion represent for your organization?
Automation for downstream applications
4 Comments
olivierlp
Community Manager
Thank you @trent_stone for publishing your idea. However, you gave the bare minimum and we need more information . The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Here are a few examples of well documented ideas:
Option to Import STEP file as Inseparable Assembly... - PTC Community
Make Shrinkwrap quality more scalable to data size... - PTC Community
Improve/fix the sheetmetal mirror feature - PTC Community
Please let us know within the next two weeks.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
trent_stone
6-Contributor
How do I edit the existing idea?
Trent Stone
Senior Design Engineer
olivierlp
Community Manager
Status changed to: Clarification Needed
You don't edit the post. Please simply additional info with an additional comment here.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
