At the moment you can switch a model from shadow with edges or without edges.
If you work with two models, one a "normal" part and the other a imported stl file model=> both inserted into an assembly it is difficult to see something.
Suggestion would be, to make the display situation differnt and dependent from the modell stored.
So the stl could be shown in display without edges and "normal" model display with edges.
You always have to switch view situation if you change between the two models.
In Creo 2 you can define in *.asm in view manager a style where stl is shown without edges and other with edges.
But this is ignored and does not work...
