modify 2D rotate highlight selected elements
When you are drawing a 2D profile and you want to rotate multiple elements using the rotate command under modify 2D; the selected elements do not highlight when you are making a selection list. this makes it difficult (impossible) to see which elements have allready been selected. Other commands under Modify 2D do highlight the selected elements, so I think this should be possible for rotate as well.
4 Comments
PeterKehoe
Regular Member
I use version 17, and it seems to highlight the elements when I select them to rotate. They also appear to highlight in 18.1 as well.
thollerweger
Regular Member
Sorry, i have voted this idea up, although 18.1 already behaves in the proposed way.
Please ignore my voting.
wdesmet
Visitor
this issue only appeared in version 18.0.
I notice that it is fixed in V18.1 so i think this idea can be closed.
PTCModerator
Emeritus
Status changed to: Archived
