modify owner of part or assembly : use instance name for new owner
If you modify the owner of a part or assembly, the instance name of the object is set to "p?" if an object with same instance name already exists in the
new assembly. But this is not good. The instance name of the object should be used instead.
E.g if you set a new owner for a part named "Pipe" and "Pipe" already exists in the new assembly the part will be renamed to "p?" (a system name).
The new part should get the new name "Pipe.number"
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
