more characters in dialogue boxes for names in ASSEMBLY
Its not just in assembly mode, but I've picked this as an example, in several places through the Creo2 UI you end up with such a limited number of characteres that you can't see the end of names, which are often the key identifiers, really annoying, all that screen space and they put a tiny little non expandable box for the names.
As ever, why?
It must have been developed by someone who just called their test parts A, B and C, sadly in the real world 18 characters often isn't enough for the part name and reference name.
4 Comments
TomD.inPDX
This is one of the problems that plagues the whole of the ribbon UI.
So much wasted space; so little detail when you need it.
sdesaulles
3-Visitor
Yes, I agree the Creo UI is indeed plagued by this sort of problem, but it needn't be.
It is not the 'Ribbon UI" per se, but just a woeful implimentation of a ribbon type menu system by PTC where dialogue boxes do not automatically resize based on content, or are just plain not big enough, or don't allow manual resize.
My screen is probably almost 10 times wider than that miserable little box, and even the box has a strip of unused white space on the right almost to rub salt in the wound.
As ever, why oh why oh why?  Who do they use to design their UI?
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
