If an assembly contains parts with a resolution 1e-2 or less or a part is corrupt the view update in Annotation ends with a signal error.
If the assembly contains only a few parts it is easy to check, what part results the problem.
If an assembly contains 100.000 parts or more you have to spend a lot of time to find the reason.
So it is important to get info about the reason. Otherwise the problem costs time and money to the customer.
