Many times there are multiple users of a design or variations where it would be helpful to organize things differently.
At this time, creating a second sheet with components rearranged requires that all the reference designators become a new sequence.
I would like to see the ability to use something similar to paste shapes with a full or partial design on a new sheet. This would allow multiple representations of the same fibers and connections.
Not an easy item to make workable. There would need to be some sort of tool to either warn if a wire/port connection is changed in one version but not the rest or a verify tool that would do it as a batch process.
