offset lines layer type
Offset lines should have their own layer type so that they may placed on a custom layer of the client's choosing, instead of being automatically placed onto the datum curves layer with all the other curves. This will give the user more control in drawings when it is desireable to view the offset lines but NOT any other 3D curves which may be present due to previous construction.
2 Comments
TomD.inPDX
Peridot
I think you can set this up but I agree that this should be there by default.  I have used the search filter function to find them all so I could move them to a layer, which means you should be able to set that up as a rule.
PTCModerator
Emeritus
Status changed to: Archived
