on Save As, ECAD .emn, Setting to Open Log Window by default
When an IDF 3.0 component has a negative z_offset, it is removed fro mthe export and a warning is generated in the export log.
Please do soemthing to bring this warning to the users attention. Either open the log file automatically when there are warnings, or create a config setting so we can mark the "Open Log Window" by default.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
