For some use cases, it is necessary to handle the depth of the first cut in area turning otherwise as the following.
This is the case, for example, for components with heat treatment and a scale layer.
Actually it´s not possible, to generate automatically a different step depth to cut this area away.
But this would be better for the cutting Tools.
Please add this functionality for area turning.
I referee to article CS281947
