"Default All" assemblies combined state is not set on Master Simplified representation & Style.
"Default All" is an unavoidable system combined state: when you open an assembly, it is the active combined state by default. But it is not perfect for us.
The problem is that this combined state use "Default Rep" as simplified representation instead of Master one, and same for Style: "Default Style" instead of Master Style.
It is a problem, we want the defaut state to set Masters Representation and Style.
Effectively, if the assembly is saved in "Default All" state, then it is not save in Masters representations and the Creoview visualization is not correct: in Creoview you must be in Master Rep.
Another reason is that "Default Rep" & "Default Style" can be redefined: so they are not really default assembly representations: the real defaults are Master Rep & Master Style.
We want the same behavior as in part: "> Default All" doesn't change Simplify Representation or Style, you stay on Masters representations.
Please see image attached.
Thanks.
2 Comments
atheobald
3-Visitor
According to the enclosed PTC-Case CS124308, this behavior is probably standard with Creo 3.0
But I also like to have this feature
olivierlp
Community Manager
Status changed to: Archived
