i want to create a pattern, the first and last feature should be located a certain distance from the start and end of my part. the distance between the features should depend on the total distance.
The position of the first feautre is defined when creating the feature.
I start the Create Pattern command. To define the position of the last feature i would like to use the reference cones to indicate the distance between the end of the part and the last feature, but the reference cone always point toward the second feature. the green reference cone can not be placed on the last feature.
