In the Module Notebook in Creo 2.0 (formerly called Layout), it is only possible with workflows (eg Mapkeys) to regenerate relations. I want to have the same function as in all other modules and to be able to regenerate the relationship with an icon. Also a shortcut key such as <Ctrl> <g> would be helpful.
